It is currently Fri Jul 18, 2025 11:22 pm
PostPosted: Tue Nov 28, 2006 10:19 am
Last Name: Johnson
State: CO.
Zip/Postal Code: 80224
I have some beautiful 20 yr old addi tops that show age beautifully. If I use superblond for F/P, will it add more color. If I want no more color, what shellac should I use?
Thanks guys,
PostPosted: Wed Nov 29, 2006 12:56 am
Last Name: Johnson
State: CO.
What is the clearest shellac? Some where I think I saw a shellac clearer than super blonde?
PostPosted: Wed Nov 29, 2006 1:26 am
Shellac.net has some platina which is a bit clearer than superblonde
Shellac.net
PostPosted: Wed Nov 29, 2006 2:06 am
Super Blonde is about as true clear as I have seen but I have not tried Shellac.net's "Platina" so I can not compare
PostPosted: Wed Nov 29, 2006 4:08 am
I occasionally use the "platina" grade from shellac.net, and it is about a close
as shellac can get to clear. You wouldn't really notice a huge difference
between super blonde and platina until the finish starts to build, but with
the cumulative tinting of coats the difference does add up.
PostPosted: Wed Nov 29, 2006 4:33 am
Last Name: Johnson
State: CO.
Thanks to all of you
